Shelly Temperatursensor in openWB anzeigen lassen
Re: Shelly Temperatursensor in openWB anzeigen lassen
stimmt für Shelly plus ist der Themperatur sensor noch nicht implementiert.
Ich brauch den Output von dem HTTP wie derNeueDet geschrieben hat. Dann kann ich es einbauen.
Smarthomeprobleme siehe hier (update ): viewtopic.php?f=14&t=5923
Hier die Antwort auf http://10.x.x.x/rpc/Shelly.GetStatus
{"ble":{},"cloud":{"connected":true},"input:0":{"id":0,"state":false},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"http", "output":true,"temperature":{"tC":50.9, "tF":123.5}},"sys":{"mac":"7C87CE560A10","restart_required":false,"time":"12:17","unixtime":1680776231,"uptime":182403,"ram_size":234352,"ram_free":154764,"fs_size":458752,"fs_free":98304,"cfg_rev":28,"kvs_rev":0,"schedule_rev":5,"webhook_rev":18,"available_updates":{}},"temperature:100":{"id": 100,"tC":70.0, "tF":158.0},"wifi":{"sta_ip":"10.x.x.x","status":"got ip","ssid":"CSA-Point-3","rssi":-70},"ws":{"connected":false}}
Ich habe das selbe Problem...
Okay danke, ich baue es nächste Woche ein.
Das ist glaub der temp sensor:
Was zeigt die shelly ap ?
Nach shelly doku:
Ids of Components linked to add-on peripherals start from 100 and are limited to 199. Ids range [0..99] is reserved for Components linked to "internal" peripherals
Nach shelly doku:
Ist drin in der neusten nightly, bitte testen,
Hey ich habe das gleiche Problem,
anbei mein Output:
{"ble":{},"cloud":{"connected":true},"input:0":{"id":0,"state":true},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"http", "output":false, "apower":0.0, "voltage":233.6, "current":0.000, "aenergy":{"total":50.139,"by_minute":[0.000,0.000,0.000],"minute_ts":1685552717},"temperature":{"tC":63.7, "tF":146.6}},"sys":{"mac":"80646FE49474","restart_required":false,"time":"19:05","unixtime":1685552719,"uptime":1437,"ram_size":234448,"ram_free":155976,"fs_size":458752,"fs_free":98304,"cfg_rev":11,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.0-beta1"},"stable":{"version":"0.14.1"}}},"temperature:100":{"id": 100,"tC":23.8, "tF":74.9},"temperature:101":{"id": 101,"tC":22.5, "tF":72.5},"wifi":{"sta_ip":"192.168.178.146","status":"got ip","ssid":"Luftstation","rssi":-76},"ws":{"connected":false}}
Zeigt mir leider keine Temperatur beim Shelly 1PM+ (poolpumpe) an.
Bei der Wärmepumpe habe ich das "alte" shelly verbaut (Wärmepumpe) - funktioniert ohne Probleme
Wäre super wenn ich meine Temperaturdaten so anzeigen lassen könnte wie bei der Wärmepumpe. Siehe Pic Version:
Stable:
1.9.301
Installiert.
Wäre super wenn das funktionieren würde.
lg
papa
anbei mein Output:
Stable:
1.9.301
Installiert.
lg
papa
Bitte auf neuste Nightly gehen. Für shelly gen2 sollte es dann gehen.
Guten Morgen,
habe gestern auf die aktuellste Nightly Version geupdatet:
installierte Version: 1.9.301.1 (2023-05-30 13:36:49 +0200 [40b3a023] )
Leider zeigt er noch immer nichts an. Shelly funktioniert: Als Theme verwende ich "colors": Nur er Vollständigkeit - verwende Shelly Plus 1PM sowie das dazugehörige Shelly Plus AddOn
Woran könnte es liegen ?
Vielen Dank für deinen Support !
lg
T
PS.: Wenn die Temperatur der Poolsteuerung angezeigt wird, werde ich als nächsten Schritt auch die Temperatur von meinem BBQ Kühlschrank anzeigen lassen - der hängt ebenfalls am Smarthome 2.0
lg
T
die Temp sensoren sollen am gerät eins oder zwei hängen (ist zumindest fürs Standardthema so).
Sonst bitte auf die Ramdisk schauen (siehe signature).
Dort hat es smarthome_device_ ret9
9 durch deine devicenummer ersetzten, den inhalt hier anzeigen,
Hallo anbei der Output der Poolpumpe (http://192.xx.xx.xx/openWB/ramdisk/smar ... evice_ret4):
"{\"power\":0,\"powerc\":0,\"on\":0,\"temp0\":36.9,\"temp1\":24.1,\"temp2\":0.0}"
Es scheint als meldet shelly brav zurück - 2 Temperatursensoren sind aktiv
Vielleicht kann man ja das Schema colors diesbezüglich erweiter, dass es bei allen Geräten angezeigt werden kann - falls dass das issue hier sein sollte.
lg
T
lg
T
sonst nehme doch mal die Poolpumpe auf position 2 der Smarthomegeräte.
