Solaredge Hybrid-System
Ihaglc
Re: Solaredge Hybrid-System
Beitrag von Ihaglc »
Hallo Lena,
Mit der Version 2023-01-02 15:19:10 +0100 [23d65949]
stimmen die Werte im Vergleich zur 1.9 wieder überein.
Vielen Dank
Thomas
PV Modul JaSolar
WR Solaredge SE7K Hybrid
Speicher LG Resu13
EV Mercedes GLC Hybrid
Ihaglc
mit der OWB 2.0 Version 2023-01-10 11:20:30 +0100 [d489ed16] werden die Werte vom EVU und Hausverbrauch nicht richtig angezeigt:
2023-01-11 13:33:40,903 - {root:61} - {INFO:MainThread} - # ***Start***
2023-01-11 13:33:40,929 - {modules.devices.solaredge.device:100} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.solaredge.counter.SolaredgeCounter object at 0xb2682910>, 'component1': <modules.devices.solaredge.inverter.SolaredgeInverter object at 0xb2682928>, 'component2': <modules.devices.solaredge.bat.SolaredgeBat object at 0xb2682328>}
2023-01-11 13:33:40,930 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-11 13:33:40,936 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Zähler']
2023-01-11 13:33:40,987 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [60, -869, 1573, -643], Scale 0
2023-01-11 13:33:41,015 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [39, 65, 27], Scale -1
2023-01-11 13:33:41,037 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [23637, 23773, 23659, 0, 0, 0, 0], Scale -2
2023-01-11 13:33:41,058 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5000], Scale -2
2023-01-11 13:33:41,097 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [9679, -9959, 9819], Scale -2
2023-01-11 13:33:41,116 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [6606689, 2079756, 3991674, 4030776, 3820542, 5281536, 1334974, 699548], Scale 0
2023-01-11 13:33:41,117 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[236.37, 237.73000000000002, 236.59], powers=[869.0, -1573.0, 643.0], currents=[3.9000000000000004, -6.5, 2.7], power_factors=[0.9679000000000001, -0.9959, 0.9819], imported=3820542.0, exported=6606689.0, power=-60.0, frequency=50.0)
2023-01-11 13:33:41,121 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-11 13:33:41,147 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [4921], Scale 0
2023-01-11 13:33:41,266 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [15434343], Scale 0
2023-01-11 13:33:41,298 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [691, 692, 691], Scale -2
2023-01-11 13:33:41,317 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [4995], Scale 0
2023-01-11 13:33:41,317 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[-6.91, -6.92, -6.91], power=-4921.0, exported=15434343.0, dc_power=-4995.0)
2023-01-11 13:33:41,321 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Speicher']
2023-01-11 13:33:41,368 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1673440410.8270175, power=-1187.0, imported=21175.61393368727, exported=15748.617039083172)
2023-01-11 13:33:41,368 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.00292803, power1: -1187, power2: -1254
2023-01-11 13:33:41,368 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: -3.57367
2023-01-11 13:33:41,369 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 0 Wh, exported: 3.57367 Wh, new state: SimCounterState(timestamp=1673440421.3679404, power=-1254.0, imported=21175.61393368727, exported=15752.190704742963)
2023-01-11 13:33:41,370 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=21175.61393368727, exported=15752.190704742963, power=-1254.0, soc=34.0)
2023-01-11 13:33:44,053 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 60, in get_values
    self.__client_error_context.reset_error_counter()
  File "/var/www/html/openWB/packages/modules/common/component_context.py", line 99, in __exit__
    raise exception
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 53, in get_values
    pub.pub_single("openWB/set/isss/heartbeat", 0, hostname=ip_address)
  File "/var/www/html/openWB/packages/helpermodules/pub.py", line 51, in pub_single
    publish.single(topic, json.dumps(payload), hostname=hostname, retain=True)
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/publish.py", line 240, in single
    multiple([msg], hostname, port, client_id, keepalive, will, auth, tls,
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/publish.py", line 176, in multiple
    client.connect(hostname, port, keepalive)
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 914, in connect
    return self.reconnect()
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 1044, in reconnect
    sock = self._create_socket_connection()
  File "/home/openwb/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
    return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
  File "/usr/lib/python3.9/socket.py", line 843, in create_connection
    raise err
  File "/usr/lib/python3.9/socket.py", line 831, in create_connection
    sock.connect(sa)
OSError: [Errno 113] No route to host
2023-01-11 13:33:44,056 - {soc.modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['SolarEdge Speicher']
2023-01-11 13:33:44,056 - {soc.modules.common.store._api:30} - {DEBUG:component2} - Saving BatState(imported=21175.61393368727, exported=15752.190704742963, power=-1254.0, soc=34.0)
2023-01-11 13:33:44,091 - {soc.modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-11 13:33:44,091 - {soc.modules.common.store._api:26} - {DEBUG:component1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=-3667.0, exported=15439766.42, dc_power=-4995.0)
2023-01-11 13:33:44,092 - {soc.modules.common.store._api:30} - {DEBUG:component1} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=-3667.0, exported=15439766.42, dc_power=-4995.0)
2023-01-11 13:33:44,093 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-11 13:33:44,113 - {soc.modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SolarEdge Zähler']
2023-01-11 13:33:44,148 - {control.counter:87} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 0: [39.7, 40.9, 55.4]
2023-01-11 13:33:44,149 - {control.counter:116} - {DEBUG:MainThread} - Verbleibende Leistung an Zähler 0: 37573.0
2023-01-11 13:33:44,151 - {control.chargepoint:349} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2023-01-11 13:33:44,153 - {control.bat:118} - {INFO:MainThread} - -1187.0W verbliebende Speicher-Leistung
2023-01-11 13:33:44,155 - {control.data:297} - {DEBUG:MainThread} - all
{'get': {'power': -1187.0, 'imported': 21175.61, 'exported': 15748.62, 'daily_exported': 23.57, 'daily_imported': 2922.51, 'soc': 34}, 'config': {'configured': True}, 'set': {'charging_power_left': -1187.0, 'switch_on_soc_reached': False}}
2023-01-11 13:33:44,155 - {control.data:297} - {DEBUG:MainThread} - bat2
{'get': {'daily_imported': 2922.51, 'daily_exported': 23.57, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'power': -1254.0, 'soc': 34, 'imported': 21175.61, 'exported': 15752.19}}
2023-01-11 13:33:44,156 - {control.data:270} - {DEBUG:MainThread} - cp_all_data
AllChargepointData(get=AllGet(daily_imported=0, daily_exported=0, power=0, imported=0, exported=0))
2023-01-11 13:33:44,156 - {control.data:297} - {DEBUG:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0.0, 0.0, 0.0], daily_imported=0, daily_exported=0, exported=0, fault_str='Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk.', fault_state=2, imported=0, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[230.0, 230.0, 230.0]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0xb0a9da48>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': '192.168.2.199', 'duo_num': 1}}, power_module={}, ev=0, name='Standard-Ladepunkt', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-01-11 13:33:44,156 - {control.data:297} - {DEBUG:MainThread} - cpt0
2023-01-11 13:33:44,157 - {control.data:297} - {DEBUG:MainThread} - counter0
{'set': {'reserved_surplus': 0, 'released_surplus': 0, 'raw_power_left': 37573.0, 'surplus_power_left': 0, 'consumption_left': 39500.0, 'raw_currents_left': [39.7, 40.9, 55.4]}, 'get': {'daily_exported': 0.0, 'daily_imported': 0.0, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'voltages': [234.0, 235.5, 237.73], 'currents': [9.3, 8.1, -6.4], 'powers': [2143.0, 1915.0, -1631.0], 'power_factors': [0.98, 1.0, -0.96], 'imported': 3802019.0, 'exported': 6606524.0, 'power': 2427.0, 'frequency': 49.99}, 'config': {'max_currents': [50, 50, 50], 'max_total_power': 40000}}
2023-01-11 13:33:44,157 - {control.data:274} - {DEBUG:MainThread} - counter_all_data
CounterAllData(get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=7348.0, invalid_home_consumption=0, daily_yield_home_consumption=1127.0000000000005))
2023-01-11 13:33:44,158 - {control.data:297} - {DEBUG:MainThread} - ct0
ChargeTemplateData(name='Standard-Ladeprofil-Vorlage', disable_after_unplug=False, prio=False, load_default=False, time_charging=TimeCharging(active=False, plans={}), chargemode=Chargemode(selected='pv_charging', pv_charging=PvCharging(min_soc_current=6, min_current=0, feed_in_limit=False, min_soc=0, max_soc=100), scheduled_charging=ScheduledCharging(plans={}), instant_charging=InstantCharging(current=17, limit=Limit(selected='none', amount=8000, soc=50))))
2023-01-11 13:33:44,158 - {control.data:297} - {DEBUG:MainThread} - ev0
EvData(set=Set(ev_template=EvTemplate(data=EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=16, max_phases=3, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=17, min_current=6, max_current_single_phase=32, battery_capacity=82, nominal_difference=2), et_num=0)), control_parameter=ControlParameter(required_current=0, required_currents=[0.0, 0.0, 0.0], phases=0, prio=False, timestamp_switch_on_off=None, timestamp_auto_phase_switch=None, timestamp_perform_phase_switch=None, submode=<Chargemode.STOP: 'stop'>, chargemode=<Chargemode.STOP: 'stop'>, used_amount_instant_charging=0, imported_at_plan_start=0, current_plan=None), charge_template=0, ev_template=0, name='Standard-Fahrzeug', tag_id=[], get=Get(soc=0, soc_timestamp='', force_soc_update=False, range=0, fault_state=0, fault_str=''))
2023-01-11 13:33:44,160 - {control.data:297} - {DEBUG:MainThread} - et0
EvTemplateData(name='Standard-Fahrzeug-Vorlage', max_current_multi_phases=17, max_phases=2, phase_switch_pause=2, prevent_phase_switch=False, prevent_charge_stop=False, control_pilot_interruption=False, control_pilot_interruption_duration=4, average_consump=22, min_current=6, max_current_single_phase=32, battery_capacity=13, nominal_difference=1)
2023-01-11 13:33:44,162 - {control.data:278} - {DEBUG:MainThread} - general_data
GeneralData(chargemode_config=ChargemodeConfig(instant_charging=InstantCharging(phases_to_use=1), pv_charging=PvCharging(bat_prio=True, charging_power_reserve=200, control_range=[0, 230], feed_in_yield=15000, phase_switch_delay=7, phases_to_use=1, rundown_power=1000, rundown_soc=95, switch_off_delay=60, switch_off_soc=95, switch_off_threshold=50, switch_on_delay=30, switch_on_soc=95, switch_on_threshold=1500), scheduled_charging=ScheduledCharging(phases_to_use=0), standby=Standby(phases_to_use=3), stop=Stop(phases_to_use=1), time_charging=TimeCharging(phases_to_use=1), unbalanced_load_limit=18, unbalanced_load=False), control_interval=10, extern_display_mode='local', extern=False, external_buttons_hw=False, grid_protection_active=False, grid_protection_configured=True, grid_protection_random_stop=0, grid_protection_timestamp='', mqtt_bridge=False, price_kwh=0.3, range_unit='km', ripple_control_receiver=RippleControlReceiver(configured=False, r1_active=False, r2_active=False))
2023-01-11 13:33:44,162 - {control.data:297} - {DEBUG:MainThread} - graph
{'config': {'duration': 120}}
2023-01-11 13:33:44,162 - {control.data:280} - {DEBUG:MainThread} - optional_data
2023-01-11 13:33:44,163 - {control.data:297} - {DEBUG:MainThread} - all
{'get': {'power': -3679.0, 'exported': 15439753.99, 'daily_exported': 4034.94, 'monthly_exported': 0, 'yearly_exported': 0}, 'config': {'configured': True}}
2023-01-11 13:33:44,163 - {control.data:297} - {DEBUG:MainThread} - pv1
{'get': {'daily_exported': 4034.94, 'monthly_exported': 0, 'yearly_exported': 0, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'power': -3667.0, 'exported': 15439766.42, 'currents': [0.0, 0.0, 0.0]}, 'config': {'max_ac_out': 7200}}
2023-01-11 13:33:44,163 - {control.data:297} - {DEBUG:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.2.129', 'current_commit': '2023-01-10 11:20:30 +0100 [d489ed16]', 'current_branch': 'master', 'current_branch_commit': '2023-01-10 11:20:30 +0100 [d489ed16]', 'current_missing_commits': [], 'boot_done': True, 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.101.1', 'datastore_version': 6, 'lastlivevaluesJson': {'timestamp': 1673440416, 'time': '13:33:36', 'grid': 2.427, 'house-power': 7.293, 'charging-all': 0.0, 'pv-all': 3.676, 'bat-all-power': -1.179, 'bat-all-soc': 34}, 'module_update_completed': True}
2023-01-11 13:33:44,164 - {control.data:310} - {DEBUG:MainThread} - device0
{'name': 'SolarEdge', 'type': 'solaredge', 'id': 0, 'configuration': {'port': 502, 'ip_address': '192.168.2.134'}}
2023-01-11 13:33:44,165 - {control.data:312} - {DEBUG:MainThread} - component0
2023-01-11 13:33:44,165 - {control.data:312} - {DEBUG:MainThread} - component1
2023-01-11 13:33:44,165 - {control.data:312} - {DEBUG:MainThread} - component2
{'name': 'SolarEdge Speicher', 'type': 'bat', 'id': 2, 'configuration': {'modbus_id': 1}}
2023-01-11 13:33:44,165 - {control.data:284} - {DEBUG:MainThread} -
2023-01-11 13:33:44,166 - {control.algorithm.algorithm:26} - {DEBUG:MainThread} - # Algorithmus-Start
2023-01-11 13:33:44,166 - {control.algorithm.algorithm:32} - {DEBUG:MainThread} - **Mindestrom setzen**
2023-01-11 13:33:44,170 - {control.algorithm.algorithm:34} - {DEBUG:MainThread} - **Sollstrom setzen**
2023-01-11 13:33:44,174 - {control.counter:159} - {DEBUG:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-01-11 13:33:44,175 - {control.counter:407} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 0W
2023-01-11 13:33:44,176 - {control.algorithm.algorithm:45} - {DEBUG:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-01-11 13:33:44,176 - {control.process:22} - {DEBUG:MainThread} - # Ladung starten.
2023-01-11 13:33:44,188 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-11 13:33:47,172 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 44, in set_current
    pub.pub_single("openWB/set/isss/Lp2Current", current,
    raise exception
  File "/var/www/html/openWB/packages/modules/chargepoints/external_openwb/chargepoint_module.py", line 41, in set_current
    pub.pub_single("openWB/set/isss/Current", current,
    raise err
    sock.connect(sa)
2023-01-11 13:33:47,176 - {control.counter:141} - {DEBUG:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-01-11 13:33:47,411 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-01-11 13:33:50,435 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-01-11 13:33:50,436 - {root:61} - {INFO:MainThread} - # ***Start***
Thomas
PV Modul JaSolar
Speicher LG Resu13
Ihaglc hat geschrieben: Mi Jan 11, 2023 12:42 pm mit der OWB 2.0 Version 2023-01-10 11:20:30 +0100 [d489ed16] werden die Werte vom EVU und Hausverbrauch nicht richtig angezeigt:
Wurde bereits behoben.
Ihaglc
Ja danke, Lutz.
Mit der neuen Version OWB 2.0 2023-01-11 13:44:22 +0100 [330b9b1f] hat sich ein neuer Fehler eingeschlichen:
Während der Dunkelheit wird PV plötzlich angezeigt und der Wert zu dem Hausverbrauch hinzugefügt. Ab ca 18:49 werden genauso plötzlich die richtigen Werte angezeigt....
new 15.txt
(1.59 MiB) 48-mal heruntergeladen
2023-01-11 18:43:30,203 - {root:61} - {INFO:MainThread} - # ***Start***
2023-01-11 18:43:30,228 - {modules.devices.solaredge.device:100} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.solaredge.counter.SolaredgeCounter object at 0xb25d75c8>, 'component1': <modules.devices.solaredge.inverter.SolaredgeInverter object at 0xb27433a0>, 'component2': <modules.devices.solaredge.bat.SolaredgeBat object at 0xb25c5bf8>}
2023-01-11 18:43:30,229 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-11 18:43:30,234 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Zähler']
2023-01-11 18:43:30,261 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [-6, -234, 119, 108], Scale 0
2023-01-11 18:43:30,281 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [18, 8, 8], Scale -1
2023-01-11 18:43:30,391 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [23441, 23522, 23546, 0, 0, 0, 0], Scale -2
2023-01-11 18:43:30,411 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5002], Scale -2
2023-01-11 18:43:30,434 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5440, -5950, -5709], Scale -2
2023-01-11 18:43:30,463 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [6606924, 2079823, 3992630, 4031750, 3820822, 5283405, 1334983, 699713], Scale 0
2023-01-11 18:43:30,463 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[234.41, 235.22, 235.46], powers=[234.0, -119.0, -108.0], currents=[1.8, -0.8, -0.8], power_factors=[0.544, -0.595, -0.5709000000000001], imported=3820822.0, exported=6606924.0, power=6.0, frequency=50.02)
2023-01-11 18:43:30,466 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-11 18:43:30,482 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [4290], Scale -1
2023-01-11 18:43:30,502 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [15438544], Scale 0
2023-01-11 18:43:30,522 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [85, 89, 85], Scale -2
2023-01-11 18:43:30,551 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [4355], Scale -1
2023-01-11 18:43:30,552 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[-0.85, -0.89, -0.85], power=-429.0, exported=15438544.0, dc_power=-435.5)
2023-01-11 18:43:30,554 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Speicher']
2023-01-11 18:43:30,592 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1673459000.951146, power=-519.0, imported=1809.338999020395, exported=2862.2942201917062)
2023-01-11 18:43:30,592 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.00267807, power1: -519, power2: -519
2023-01-11 18:43:30,593 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: -1.38992
2023-01-11 18:43:30,593 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 0 Wh, exported: 1.38992 Wh, new state: SimCounterState(timestamp=1673459010.592208, power=-519.0, imported=1809.338999020395, exported=2863.684139966437)
2023-01-11 18:43:30,594 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=1809.338999020395, exported=2863.684139966437, power=-519.0, soc=28.0)
2023-01-11 18:43:33,345 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
    raise exception
    raise err
    sock.connect(sa)
2023-01-11 18:43:33,347 - {soc.modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['SolarEdge Speicher']
2023-01-11 18:43:33,348 - {soc.modules.common.store._api:30} - {DEBUG:component2} - Saving BatState(imported=1809.338999020395, exported=2863.684139966437, power=-519.0, soc=28.0)
2023-01-11 18:43:33,387 - {soc.modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-11 18:43:33,387 - {soc.modules.common.store._api:26} - {DEBUG:component1} - Raw data InverterState(currents=[0.0, 0.0, 0.0], power=90.0, exported=15437489.66, dc_power=-435.5)
2023-01-11 18:43:33,388 - {soc.modules.common.store._api:30} - {DEBUG:component1} - Saving InverterState(currents=[0.0, 0.0, 0.0], power=90.0, exported=15437489.66, dc_power=-435.5)
2023-01-11 18:43:33,389 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-11 18:43:33,395 - {helpermodules.setdata:287} - {ERROR:Thread-6} - Payload ungültig: Topic openWB/set/pv/1/get/power, Payload 90.0 liegt in keinem der angegebenen Wertebereiche.
2023-01-11 18:43:33,413 - {soc.modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SolarEdge Zähler']
2023-01-11 18:43:33,413 - {soc.modules.common.store._api:30} - {DEBUG:component0} - Saving CounterState(voltages=[234.41, 235.22, 235.46], powers=[234.0, -119.0, -108.0], currents=[1.8, -0.8, -0.8], power_factors=[0.544, -0.595, -0.5709000000000001], imported=3820822.0, exported=6606924.0, power=6.0, frequency=50.02)
2023-01-11 18:43:33,463 - {control.counter:87} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 0: [47.2, 49.8, 49.8]
2023-01-11 18:43:33,465 - {control.counter:116} - {DEBUG:MainThread} - Verbleibende Leistung an Zähler 0: 39994.0
2023-01-11 18:43:33,466 - {control.chargepoint:349} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2023-01-11 18:43:33,467 - {control.bat:118} - {INFO:MainThread} - -519.0W verbliebende Speicher-Leistung
2023-01-11 18:43:33,468 - {control.data:297} - {DEBUG:MainThread} - all
{'get': {'power': -519.0, 'imported': 1809.34, 'exported': 2862.29, 'daily_exported': 73.62, 'daily_imported': 3498.2, 'soc': 28}, 'config': {'configured': True}, 'set': {'charging_power_left': -519.0, 'switch_on_soc_reached': False}}
2023-01-11 18:43:33,468 - {control.data:297} - {DEBUG:MainThread} - bat2
{'get': {'daily_imported': 3498.2, 'daily_exported': 73.62, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'power': -519.0, 'soc': 28, 'imported': 1809.34, 'exported': 2863.68}}
2023-01-11 18:43:33,468 - {control.data:270} - {DEBUG:MainThread} - cp_all_data
2023-01-11 18:43:33,469 - {control.data:297} - {DEBUG:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0.0, 0.0, 0.0], daily_imported=0, daily_exported=0, exported=0, fault_str='Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk.', fault_state=2, imported=0, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[230.0, 230.0, 230.0]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0xb134f550>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': '192.168.2.199', 'duo_num': 1}}, power_module={}, ev=0, name='Standard-Ladepunkt', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-01-11 18:43:33,469 - {control.data:297} - {DEBUG:MainThread} - cpt0
2023-01-11 18:43:33,469 - {control.data:297} - {DEBUG:MainThread} - counter0
{'set': {'reserved_surplus': 0, 'released_surplus': 0, 'raw_power_left': 39994.0, 'surplus_power_left': 0, 'consumption_left': 39500.0, 'raw_currents_left': [47.2, 49.8, 49.8]}, 'get': {'daily_exported': 400.0, 'daily_imported': 18802.0, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'voltages': [234.41, 235.22, 235.46], 'currents': [1.8, -0.8, -0.8], 'powers': [234.0, -119.0, -108.0], 'power_factors': [0.54, -0.59, -0.57], 'imported': 3820822.0, 'exported': 6606924.0, 'power': 6.0, 'frequency': 50.02}, 'config': {'max_currents': [50, 50, 50], 'max_total_power': 40000}}
2023-01-11 18:43:33,469 - {control.data:274} - {DEBUG:MainThread} - counter_all_data
CounterAllData(get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=966.0, invalid_home_consumption=0, daily_yield_home_consumption=23916.0))
2023-01-11 18:43:33,470 - {control.data:297} - {DEBUG:MainThread} - ct0
2023-01-11 18:43:33,471 - {control.data:297} - {DEBUG:MainThread} - ev0
2023-01-11 18:43:33,471 - {control.data:297} - {DEBUG:MainThread} - et0
2023-01-11 18:43:33,471 - {control.data:278} - {DEBUG:MainThread} - general_data
2023-01-11 18:43:33,471 - {control.data:297} - {DEBUG:MainThread} - graph
2023-01-11 18:43:33,471 - {control.data:280} - {DEBUG:MainThread} - optional_data
2023-01-11 18:43:33,472 - {control.data:297} - {DEBUG:MainThread} - all
{'get': {'power': -441.0, 'exported': 15437490.05, 'daily_exported': 1993.59, 'monthly_exported': 0, 'yearly_exported': 0}, 'config': {'configured': True}}
2023-01-11 18:43:33,472 - {control.data:297} - {DEBUG:MainThread} - pv1
{'get': {'daily_exported': 1993.59, 'monthly_exported': 0, 'yearly_exported': 0, 'fault_str': 'Kein Fehler.', 'fault_state': 0, 'power': -441.0, 'exported': 15437489.66, 'currents': [0.0, 0.0, 0.0]}, 'config': {'max_ac_out': 7200}}
2023-01-11 18:43:33,473 - {control.data:297} - {DEBUG:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.2.129', 'current_commit': '2023-01-11 13:44:22 +0100 [330b9b1f]', 'current_branch': 'master', 'current_branch_commit': '2023-01-11 13:44:22 +0100 [330b9b1f]', 'current_missing_commits': [], 'boot_done': True, 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.101.1', 'datastore_version': 6, 'lastlivevaluesJson': {'timestamp': 1673459006, 'time': '18:43:26', 'grid': 0.024, 'house-power': 0.984, 'charging-all': 0.0, 'pv-all': 0.441, 'bat-all-power': -0.511, 'bat-all-soc': 28}, 'module_update_completed': True}
2023-01-11 18:43:33,473 - {control.data:310} - {DEBUG:MainThread} - device0
2023-01-11 18:43:33,473 - {control.data:312} - {DEBUG:MainThread} - component0
2023-01-11 18:43:33,473 - {control.data:312} - {DEBUG:MainThread} - component1
2023-01-11 18:43:33,474 - {control.data:312} - {DEBUG:MainThread} - component2
2023-01-11 18:43:33,474 - {control.data:284} - {DEBUG:MainThread} -
2023-01-11 18:43:33,474 - {control.algorithm.algorithm:26} - {DEBUG:MainThread} - # Algorithmus-Start
2023-01-11 18:43:33,474 - {control.algorithm.algorithm:32} - {DEBUG:MainThread} - **Mindestrom setzen**
2023-01-11 18:43:33,477 - {control.algorithm.algorithm:34} - {DEBUG:MainThread} - **Sollstrom setzen**
2023-01-11 18:43:33,479 - {control.counter:159} - {DEBUG:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-01-11 18:43:33,479 - {control.counter:407} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 0W
2023-01-11 18:43:33,479 - {control.algorithm.algorithm:45} - {DEBUG:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-01-11 18:43:33,480 - {control.process:22} - {DEBUG:MainThread} - # Ladung starten.
2023-01-11 18:43:33,481 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-11 18:43:36,465 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
    raise exception
    raise err
    sock.connect(sa)
2023-01-11 18:43:36,468 - {control.counter:141} - {DEBUG:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-01-11 18:43:36,718 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-01-11 18:43:40,734 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-01-11 18:43:40,735 - {root:61} - {INFO:MainThread} - # ***Start***
Thomas
PV Modul JaSolar
Speicher LG Resu13
Ihaglc
Leider stimmen mit der Version 2023-01-19 07:48:19 +0100 [bdff6e82] jetzt wieder nicht die Werte vom Hausverbrauch und der PV
2023-01-19 12:01:30,294 - {root:61} - {INFO:MainThread} - # ***Start***
2023-01-19 12:01:30,318 - {modules.devices.solaredge.device:100} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.solaredge.counter.SolaredgeCounter object at 0xb2649910>, 'component1': <modules.devices.solaredge.inverter.SolaredgeInverter object at 0xb1cc25b0>, 'component2': <modules.devices.solaredge.bat.SolaredgeBat object at 0xb1cc2598>}
2023-01-19 12:01:30,319 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-19 12:01:30,324 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Zähler']
2023-01-19 12:01:30,383 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [168, -161, 184, 144], Scale 0
2023-01-19 12:01:30,424 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [16, 10, 8], Scale -1
2023-01-19 12:01:30,451 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [23490, 23575, 23554, 0, 0, 0, 0], Scale -2
2023-01-19 12:01:30,493 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [4997], Scale -2
2023-01-19 12:01:30,521 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [4189, -7720, -6800], Scale -2
2023-01-19 12:01:30,633 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [6610108, 2081010, 3999290, 4041547, 3927311, 5361745, 1365119, 712187], Scale 0
2023-01-19 12:01:30,634 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[234.9, 235.75, 235.54], powers=[161.0, -184.0, -144.0], currents=[1.6, -1.0, -0.8], power_factors=[0.4189, -0.772, -0.68], imported=3927311.0, exported=6610108.0, power=-168.0, frequency=49.97)
2023-01-19 12:01:30,636 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-19 12:01:30,674 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5730], Scale -1
2023-01-19 12:01:30,693 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [15479345], Scale 0
2023-01-19 12:01:30,713 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [96, 100, 96], Scale -2
2023-01-19 12:01:30,732 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5817], Scale -1
2023-01-19 12:01:30,733 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[-0.96, -1.0, -0.96], power=-573.0, exported=15479345.0, dc_power=-581.7)
2023-01-19 12:01:30,734 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Speicher']
2023-01-19 12:01:30,782 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1674126081.112339, power=0.0, imported=24500.715827321652, exported=24378.198947367135)
2023-01-19 12:01:30,783 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.00268614, power1: 0, power2: 0
2023-01-19 12:01:30,783 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: 0
2023-01-19 12:01:30,783 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 0 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1674126090.7824259, power=0.0, imported=24500.715827321652, exported=24378.198947367135)
2023-01-19 12:01:30,784 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=24500.715827321652, exported=24378.198947367135, power=0.0, soc=10.0)
2023-01-19 12:01:33,415 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
    raise exception
    raise err
    sock.connect(sa)
2023-01-19 12:01:33,417 - {soc.modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['SolarEdge Speicher']
2023-01-19 12:01:33,418 - {soc.modules.common.store._api:30} - {DEBUG:component2} - Saving BatState(imported=24500.715827321652, exported=24378.198947367135, power=0.0, soc=10.0)
2023-01-19 12:01:33,456 - {soc.modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-19 12:01:33,458 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-19 12:01:33,469 - {soc.modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SolarEdge Zähler']
2023-01-19 12:01:33,469 - {soc.modules.common.store._api:30} - {DEBUG:component0} - Saving CounterState(voltages=[234.9, 235.75, 235.54], powers=[161.0, -184.0, -144.0], currents=[1.6, -1.0, -0.8], power_factors=[0.4189, -0.772, -0.68], imported=3927311.0, exported=6610108.0, power=-168.0, frequency=49.97)
2023-01-19 12:01:33,530 - {control.counter:137} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 0: [47.4, 50.0, 49.8]
2023-01-19 12:01:33,530 - {control.counter:166} - {DEBUG:MainThread} - Verbleibende Leistung an Zähler 0: 40168.0
2023-01-19 12:01:33,532 - {control.chargepoint:349} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2023-01-19 12:01:33,535 - {control.bat_all:145} - {INFO:MainThread} - 0.0W verbliebende Speicher-Leistung
2023-01-19 12:01:33,536 - {control.counter_all:83} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -156.0W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]
2023-01-19 12:01:33,537 - {control.data:334} - {DEBUG:MainThread} - bat2
BatData(get=Get(soc=10, daily_exported=2957.44, daily_imported=0.0, imported=24500.72, exported=24378.2, fault_state=0, fault_str='Kein Fehler.', power=0.0))
2023-01-19 12:01:33,537 - {control.data:305} - {DEBUG:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=10, daily_exported=2957.44, daily_imported=0.0, imported=24500.72, exported=24378.2, power=0.0), set=Set(charging_power_left=0.0, switch_on_soc_reached=False))
2023-01-19 12:01:33,537 - {control.data:306} - {DEBUG:MainThread} - cp_all_data
2023-01-19 12:01:33,537 - {control.data:334} - {DEBUG:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0.0, 0.0, 0.0], daily_imported=0, daily_exported=0, exported=0, fault_str='Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk.', fault_state=2, imported=0, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[230.0, 230.0, 230.0]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0xb0acdb80>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': '192.168.2.199', 'duo_num': 1}}, power_module={}, ev=0, name='Standard-Ladepunkt', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-01-19 12:01:33,538 - {control.data:334} - {DEBUG:MainThread} - cpt0
2023-01-19 12:01:33,538 - {control.data:334} - {DEBUG:MainThread} - counter0
CounterData(config=Config(max_currents=[50, 50, 50], max_total_power=40000), get=Get(powers=[161.0, -184.0, -144.0], currents=[1.6, -1.0, -0.8], voltages=[234.9, 235.75, 235.54], power_factors=[0.42, -0.77, -0.68], unbalanced_load=0, frequency=49.97, daily_exported=23.0, daily_imported=3370.0, imported=3927311.0, exported=6610108.0, fault_state=1, fault_str='Der Wert für den Hausverbrauch ist nicht plausibel (negativ). Bitte die Leistungen der Komponenten und die Anordnung in der Hierarchie prüfen.', power=-168.0), set=Set(reserved_surplus=0, released_surplus=0, raw_power_left=40168.0, raw_currents_left=[47.4, 50.0, 49.8], surplus_power_left=0, state_str=''))
2023-01-19 12:01:33,542 - {control.data:310} - {DEBUG:MainThread} - counter_all_data
CounterAllData(get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=0, invalid_home_consumption=3, daily_yield_home_consumption=3347.0))
2023-01-19 12:01:33,542 - {control.data:334} - {DEBUG:MainThread} - ct0
2023-01-19 12:01:33,543 - {control.data:334} - {DEBUG:MainThread} - ev0
2023-01-19 12:01:33,543 - {control.data:334} - {DEBUG:MainThread} - et0
2023-01-19 12:01:33,543 - {control.data:314} - {DEBUG:MainThread} - general_data
2023-01-19 12:01:33,543 - {control.data:315} - {DEBUG:MainThread} - graph_data
2023-01-19 12:01:33,544 - {control.data:316} - {DEBUG:MainThread} - optional_data
2023-01-19 12:01:33,545 - {control.data:334} - {DEBUG:MainThread} - pv1
PvData(config=Config(max_ac_out=7200), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=1716.96, monthly_exported=0, yearly_exported=0, imported=0, exported=15479368.52, fault_state=0, fault_str='Kein Fehler.', power=-12.0))
2023-01-19 12:01:33,546 - {control.data:318} - {DEBUG:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=1716.96, monthly_exported=0, yearly_exported=0, exported=15479368.52, power=-12.0))
2023-01-19 12:01:33,546 - {control.data:334} - {DEBUG:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.2.129', 'current_commit': '2023-01-19 07:48:19 +0100 [bdff6e82]', 'current_branch': 'master', 'current_branch_commit': '2023-01-19 07:48:19 +0100 [bdff6e82]', 'current_missing_commits': [], 'boot_done': True, 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.101.1', 'datastore_version': 6, 'lastlivevaluesJson': {'timestamp': 1674126087, 'time': '12:01:27', 'grid': -0.162, 'house-power': 0.0, 'charging-all': 0.0, 'pv-all': 0.012, 'bat-all-power': 0.0, 'bat-all-soc': 10}, 'module_update_completed': True}
2023-01-19 12:01:33,546 - {control.data:347} - {DEBUG:MainThread} - device0
2023-01-19 12:01:33,547 - {control.data:349} - {DEBUG:MainThread} - component0
2023-01-19 12:01:33,547 - {control.data:349} - {DEBUG:MainThread} - component1
2023-01-19 12:01:33,547 - {control.data:349} - {DEBUG:MainThread} - component2
2023-01-19 12:01:33,547 - {control.data:321} - {DEBUG:MainThread} -
2023-01-19 12:01:33,547 - {control.algorithm.algorithm:26} - {DEBUG:MainThread} - # Algorithmus
2023-01-19 12:01:33,548 - {control.algorithm.algorithm:32} - {DEBUG:MainThread} - **Mindestrom setzen**
2023-01-19 12:01:33,550 - {control.algorithm.algorithm:34} - {DEBUG:MainThread} - **Sollstrom setzen**
2023-01-19 12:01:33,552 - {control.counter:203} - {DEBUG:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-01-19 12:01:33,553 - {control.counter:466} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 0W
2023-01-19 12:01:33,553 - {control.algorithm.algorithm:45} - {DEBUG:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-01-19 12:01:33,553 - {control.process:22} - {DEBUG:MainThread} - # Ladung starten.
2023-01-19 12:01:33,554 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-19 12:01:36,534 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
    raise exception
    raise err
    sock.connect(sa)
2023-01-19 12:01:36,540 - {control.counter:191} - {DEBUG:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-01-19 12:01:36,768 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-01-19 12:01:40,806 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-01-19 12:01:40,806 - {root:61} - {INFO:MainThread} - # ***Start***
Thomas
PV Modul JaSolar
Speicher LG Resu13
Ihaglc
Scheint wohl untergegangen zu sein:
Nach meiner letzten Meldung hat sich in den anschliessenden verschiedenen Versionen bis zur jetzt aktuellen OWB2.0 version 2023-01-27 07:55:01 +0100 [ff4a03ca] nichts an den Messungen geändert; die Berechnungen von PV und Hausverbrauch sind nach wie vor nicht richtig.
2023-01-28 15:16:30,043 - {root:61} - {INFO:MainThread} - # ***Start***
2023-01-28 15:16:30,069 - {modules.devices.solaredge.device:100} - {DEBUG:device0} - Start device reading {'component0': <modules.devices.solaredge.counter.SolaredgeCounter object at 0xb2664940>, 'component1': <modules.devices.solaredge.inverter.SolaredgeInverter object at 0xb2664850>, 'component2': <modules.devices.solaredge.bat.SolaredgeBat object at 0xb26643b8>}
2023-01-28 15:16:30,070 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-28 15:16:30,075 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Zähler']
2023-01-28 15:16:30,113 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [-28, -272, 78, 165], Scale 0
2023-01-28 15:16:30,132 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [13, 6, 7], Scale -1
2023-01-28 15:16:30,153 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [23743, 23815, 23881, 0, 0, 0, 0], Scale -2
2023-01-28 15:16:30,194 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [4997], Scale -2
2023-01-28 15:16:30,213 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [7960, -4830, -9259], Scale -2
2023-01-28 15:16:30,235 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [6610614, 2081272, 4003197, 4044282, 4091950, 5469818, 1408283, 731986], Scale 0
2023-01-28 15:16:30,235 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data CounterState(voltages=[237.43, 238.15, 238.81], powers=[272.0, -78.0, -165.0], currents=[1.3, -0.6000000000000001, -0.7000000000000001], power_factors=[0.796, -0.48300000000000004, -0.9259000000000001], imported=4091950.0, exported=6610614.0, power=28.0, frequency=49.97)
2023-01-28 15:16:30,242 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-28 15:16:30,264 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5730], Scale -1
2023-01-28 15:16:30,284 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [15498811], Scale 0
2023-01-28 15:16:30,337 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [82, 85, 82], Scale -2
2023-01-28 15:16:30,365 - {modules.devices.solaredge.scale:16} - {DEBUG:device0} - Registers [5817], Scale -1
2023-01-28 15:16:30,366 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data InverterState(currents=[-0.8200000000000001, -0.85, -0.8200000000000001], power=-573.0, exported=15498811.0, dc_power=-581.7)
2023-01-28 15:16:30,372 - {soc.modules.common.component_context:24} - {DEBUG:device0} - Update Komponente ['SolarEdge Speicher']
2023-01-28 15:16:30,475 - {modules.common.simcount._simcount:38} - {DEBUG:device0} - Previous state: SimCounterState(timestamp=1674915380.8960636, power=1999.0, imported=1478.9031295084615, exported=98.43074275692284)
2023-01-28 15:16:30,475 - {modules.common.simcount._calculate:13} - {DEBUG:device0} - time passed: 0.00266082, power1: 1999, power2: 2003
2023-01-28 15:16:30,475 - {modules.common.simcount._calculate:29} - {DEBUG:device0} - power did not change sign. Total energy: 5.3243
2023-01-28 15:16:30,476 - {modules.common.simcount._simcount:47} - {DEBUG:device0} - imported: 5.3243 Wh, exported: 0 Wh, new state: SimCounterState(timestamp=1674915390.475008, power=2003.0, imported=1484.2274261289497, exported=98.43074275692284)
2023-01-28 15:16:30,477 - {soc.modules.common.store._api:26} - {DEBUG:device0} - Raw data BatState(imported=1484.2274261289497, exported=98.43074275692284, power=2003.0, soc=21.0)
2023-01-28 15:16:33,167 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
    raise exception
    raise err
    sock.connect(sa)
2023-01-28 15:16:33,169 - {soc.modules.common.component_context:24} - {DEBUG:component2} - Update Komponente ['SolarEdge Speicher']
2023-01-28 15:16:33,170 - {soc.modules.common.store._api:30} - {DEBUG:component2} - Saving BatState(imported=1484.2274261289497, exported=98.43074275692284, power=2003.0, soc=21.0)
2023-01-28 15:16:33,204 - {soc.modules.common.component_context:24} - {DEBUG:component1} - Update Komponente ['SolarEdge Wechselrichter']
2023-01-28 15:16:33,205 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-28 15:16:33,212 - {soc.modules.common.component_context:24} - {DEBUG:component0} - Update Komponente ['SolarEdge Zähler']
2023-01-28 15:16:33,213 - {soc.modules.common.store._api:30} - {DEBUG:component0} - Saving CounterState(voltages=[237.43, 238.15, 238.81], powers=[272.0, -78.0, -165.0], currents=[1.3, -0.6000000000000001, -0.7000000000000001], power_factors=[0.796, -0.48300000000000004, -0.9259000000000001], imported=4091950.0, exported=6610614.0, power=28.0, frequency=49.97)
2023-01-28 15:16:33,248 - {control.bat_all:128} - {WARNING:MainThread} - Bat 2: Die maximale Entladeleistung des Wechselrichters ist erreicht.
2023-01-28 15:16:33,290 - {control.counter:137} - {DEBUG:MainThread} - Verbleibende Ströme an Zähler 0: [47.7, 49.6, 49.7]
2023-01-28 15:16:33,290 - {control.counter:166} - {DEBUG:MainThread} - Verbleibende Leistung an Zähler 0: 39972.0
2023-01-28 15:16:33,293 - {control.chargepoint:354} - {INFO:MainThread} - LP 3: Keine Ladung, da kein Auto angesteckt ist.
2023-01-28 15:16:33,294 - {control.bat_all:145} - {INFO:MainThread} - -50W verbliebende Speicher-Leistung
2023-01-28 15:16:33,295 - {control.counter_all:83} - {ERROR:MainThread} - Ungültiger Hausverbrauch: -1963.0W, Berücksichtigte Komponenten neben EVU [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]
2023-01-28 15:16:33,296 - {control.data:334} - {DEBUG:MainThread} - bat2
BatData(get=Get(soc=21, daily_exported=97.46, daily_imported=1278.38, imported=1484.23, exported=98.43, fault_state=0, fault_str='Kein Fehler.', power=2003.0))
2023-01-28 15:16:33,296 - {control.data:305} - {DEBUG:MainThread} - bat_all_data
BatAllData(config=Config(configured=True), get=Get(soc=21, daily_exported=97.46, daily_imported=1278.38, imported=1478.9, exported=98.43, power=1999.0), set=Set(charging_power_left=-50, switch_on_soc_reached=False))
2023-01-28 15:16:33,297 - {control.data:306} - {DEBUG:MainThread} - cp_all_data
2023-01-28 15:16:33,297 - {control.data:334} - {DEBUG:MainThread} - cp3
ChargepointData(get=Get(charge_state=False, connected_vehicle=ConnectedVehicle(config=ConnectedConfig(average_consumption=17, charge_template=0, chargemode='stop', current_plan=0, ev_template=0, priority=False, time_charging_in_use=False), info=ConnectedInfo(id=0, name='Ladepunkt'), soc=ConnectedSoc(fault_str='Kein Fehler.', fault_state=0, range_charged=0, range_unit='km', range=0, soc=0, timestamp=None)), currents=[0.0, 0.0, 0.0], daily_imported=0, daily_exported=0, exported=0, fault_str='Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk.', fault_state=2, imported=0, phases_in_use=0, plug_state=False, power=0, rfid_timestamp=None, rfid=None, state_str='Keine Ladung, da kein Auto angesteckt ist.', voltages=[230.0, 230.0, 230.0]), set=Set(change_ev_permitted=False, charging_ev=-1, charging_ev_prev=-1, current=0, energy_to_charge=0, loadmanagement_available=True, log=Log(chargemode_log_entry='_', imported_at_mode_switch=0, imported_at_plugtime=0, imported_since_mode_switch=0, imported_since_plugged=0, range_charged=0, time_charged='00:00', timestamp_start_charging=None), manual_lock=False, phases_to_use=0, plug_state_prev=False, plug_time=None, required_power=0, rfid=None, target_current=0, charging_ev_data=<control.ev.Ev object at 0xb0ad6e38>), config=Config(connection_module={'type': 'external_openwb', 'name': 'Externe openWB', 'configuration': {'ip_address': '192.168.2.199', 'duo_num': 1}}, power_module={}, ev=0, name='Standard-Ladepunkt', type='external_openwb', template=0, connected_phases=3, phase_1=1, auto_phase_switch_hw=True, control_pilot_interruption_hw=True, id=3))
2023-01-28 15:16:33,297 - {control.data:334} - {DEBUG:MainThread} - cpt0
2023-01-28 15:16:33,299 - {control.data:334} - {DEBUG:MainThread} - counter0
CounterData(config=Config(max_currents=[50, 50, 50], max_total_power=40000), get=Get(powers=[272.0, -78.0, -165.0], currents=[1.3, -0.6, -0.7], voltages=[237.43, 238.15, 238.81], power_factors=[0.8, -0.48, -0.93], unbalanced_load=0, frequency=49.97, daily_exported=222.0, daily_imported=64572.0, imported=4091950.0, exported=6610614.0, fault_state=1, fault_str='Der Wert für den Hausverbrauch ist nicht plausibel (negativ). Bitte die Leistungen der Komponenten und die Anordnung in der Hierarchie prüfen.', power=28.0), set=Set(reserved_surplus=0, released_surplus=0, raw_power_left=39972.0, raw_currents_left=[47.7, 49.6, 49.7], surplus_power_left=0, state_str=''))
2023-01-28 15:16:33,299 - {control.data:310} - {DEBUG:MainThread} - counter_all_data
CounterAllData(get=Get(hierarchy=[{'id': 0, 'type': 'counter', 'children': [{'id': 1, 'type': 'inverter', 'children': [{'id': 2, 'type': 'bat', 'children': []}]}, {'id': 3, 'type': 'cp', 'children': []}, {'id': 2, 'type': 'bat', 'children': []}]}]), set=Set(loadmanagement_active=False, home_consumption=0, invalid_home_consumption=3, daily_yield_home_consumption=64350.0))
2023-01-28 15:16:33,300 - {control.data:334} - {DEBUG:MainThread} - ct0
2023-01-28 15:16:33,300 - {control.data:334} - {DEBUG:MainThread} - ev0
2023-01-28 15:16:33,300 - {control.data:334} - {DEBUG:MainThread} - et0
2023-01-28 15:16:33,300 - {control.data:314} - {DEBUG:MainThread} - general_data
2023-01-28 15:16:33,301 - {control.data:315} - {DEBUG:MainThread} - graph_data
2023-01-28 15:16:33,301 - {control.data:316} - {DEBUG:MainThread} - optional_data
2023-01-28 15:16:33,301 - {control.data:334} - {DEBUG:MainThread} - pv1
PvData(config=Config(max_ac_out=7200), get=Get(currents=[0.0, 0.0, 0.0], daily_exported=0.0, monthly_exported=0, yearly_exported=0, exported=15479368.52, fault_state=0, fault_str='Kein Fehler.', power=-12.0))
2023-01-28 15:16:33,302 - {control.data:318} - {DEBUG:MainThread} - pv_all_data
PvAllData(config=Config(configured=True), get=Get(daily_exported=0.0, monthly_exported=0, yearly_exported=0, exported=15479368.52, power=-12.0))
2023-01-28 15:16:33,302 - {control.data:334} - {DEBUG:MainThread} - system
{'update_in_progress': False, 'perform_update': False, 'ip_address': '192.168.2.129', 'current_commit': '2023-01-27 07:55:01 +0100 [ff4a03ca]', 'current_branch': 'master', 'current_branch_commit': '2023-01-27 07:55:01 +0100 [ff4a03ca]', 'current_missing_commits': [], 'boot_done': True, 'dataprotection_acknowledged': False, 'debug_level': 10, 'release_train': 'master', 'version': '1.99.101.1', 'datastore_version': 6, 'lastlivevaluesJson': {'timestamp': 1674915386, 'time': '15:16:26', 'grid': 0.007, 'house-power': 0.0, 'charging-all': 0.0, 'pv-all': 0.012, 'bat-all-power': 1.999, 'bat-all-soc': 21}, 'module_update_completed': True}
2023-01-28 15:16:33,302 - {control.data:347} - {DEBUG:MainThread} - device0
2023-01-28 15:16:33,302 - {control.data:349} - {DEBUG:MainThread} - component0
2023-01-28 15:16:33,302 - {control.data:349} - {DEBUG:MainThread} - component1
2023-01-28 15:16:33,302 - {control.data:349} - {DEBUG:MainThread} - component2
2023-01-28 15:16:33,302 - {control.data:321} - {DEBUG:MainThread} -
2023-01-28 15:16:33,302 - {control.algorithm.algorithm:26} - {DEBUG:MainThread} - # Algorithmus
2023-01-28 15:16:33,303 - {control.algorithm.algorithm:32} - {DEBUG:MainThread} - **Mindestrom setzen**
2023-01-28 15:16:33,304 - {control.algorithm.algorithm:34} - {DEBUG:MainThread} - **Sollstrom setzen**
2023-01-28 15:16:33,306 - {control.counter:203} - {DEBUG:MainThread} - Überschuss zur PV-geführten Ladung: 0W
2023-01-28 15:16:33,306 - {control.counter:466} - {DEBUG:MainThread} - Zähler 0: Begrenzung der verbleibenden Leistung auf 0W
2023-01-28 15:16:33,306 - {control.algorithm.algorithm:45} - {DEBUG:MainThread} - **Keine Leistung für PV-geführtes Laden übrig.**
2023-01-28 15:16:33,306 - {control.process:22} - {DEBUG:MainThread} - # Ladung starten.
2023-01-28 15:16:33,308 - {soc.modules.common.component_context:24} - {DEBUG:cp3} - Update Komponente ['Ladepunkt']
2023-01-28 15:16:36,287 - {soc.modules.common.fault_state:40} - {ERROR:cp3} - Ladepunkt: FaultState FaultStateLevel.ERROR, FaultStr Die Verbindung zum Host ist fehlgeschlagen. Überprüfe Adresse und Netzwerk., Traceback:
    raise exception
    raise err
    sock.connect(sa)
2023-01-28 15:16:36,292 - {control.counter:191} - {DEBUG:MainThread} - 0W reservierte EVU-Leistung, 0W freigegebene EVU-Leistung
2023-01-28 15:16:36,527 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=update, args=(), kwargs={})
2023-01-28 15:16:40,544 - {schedule:660} - {DEBUG:MainThread} - Running job Job(interval=1, unit=minutes, do=handler10Sec, args=(), kwargs={})
2023-01-28 15:16:40,545 - {root:61} - {INFO:MainThread} - # ***Start***
Thomas
PV Modul JaSolar
Speicher LG Resu13
Beitrag von LenaK »
Nun sollte die PV-Leistung aktualisiert werden. Bitte nochmal prüfen, ob die Werte in den verschiedenen Szenarien (Akku lädt, nicht, aus dem Netz) passen.
Ihaglc
Danke für die Änderung in OWB 2.0 ( 2023-02-01 17:11:40 +0100 [c26f4ce1] )
Zwischenmeldung: PV und Hausverbrauch wird jetzt richtig angezeigt.
Rückmeldung zum Speicher erfolgt später, wenn mal wieder die Sonne kräftiger scheint...
Thomas
PV Modul JaSolar
Speicher LG Resu13
Ihaglc
Ergänzung:
2. Fall Laden des Speichers mit EVU Leistung:
Sie wird fälschlicher Weise auch als PV Leistung angezeigt
new 25.txt
(1.12 MiB) 56-mal heruntergeladen
3. Fall Laden des Speichers mit PV Leistung:
Die Werte werden in diesem Fall richtig angezeigt
Thomas
PV Modul JaSolar
Speicher LG Resu13
Ihaglc
Fall 4 Entladen des Speichers:
Werte stimmen überein.
Bleibt also nur Fall 2 zur evt. Korrektur des kleinen Fehlers :D
Thomas
PV Modul JaSolar
Speicher LG Resu13
