Alternative Anbindung von Huawei WR
danielrudolf
Re: Alternative Anbindung von Huawei WR
Beitrag von danielrudolf »
Hab es nun doch noch geschafft. Hab gestern in der Nacht mich noch mit Node-Red auseinandergesetzt. Dort habe ich es geschafft den Wert per Mqtt an die OpenWB zu senden.
sehr schön - Glückwunsch!
Kannst Du den Flow noch beistellen, dass alle etwas davon haben?
danielrudolf
Sehr gerne :)
Ich lasse ihm alle 2 Sekunden die Werte senden. Ein Wert von der Huawei habe ich *-1 gerechnet.
        "id": "b54d4ffd1e13f824",
        "type": "mqtt out",
        "z": "05ef9b6ff2d2232d",
        "name": "",
        "topic": "openWB/set/pv/8/get/power",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "eca40c603102ca88",
        "x": 920,
        "y": 140,
        "wires": []
        "id": "bce8f1d54263df19",
        "type": "api-current-state",
        "name": "Inverter Eingangsleistung",
        "server": "ad5ff102.51ed",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "sensor.inverter_eingangsleistung",
        "state_type": "str",
        "blockInputOverrides": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 450,
        "y": 140,
        "wires": [
                "ebd08ea3.75c5f"
        "id": "bf88582d62e42d3a",
        "type": "inject",
        "name": "",
        "props": [],
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 110,
        "y": 220,
        "wires": [
                "60c9a819108d7648",
                "bce8f1d54263df19",
                "e5ee2bb810b6e5b9",
                "e844d098effc0b56",
                "535076dc94ee8dda",
                "44a4f5ef0c5b567c"
        "id": "60c9a819108d7648",
        "name": "Inverter Gesamtenergieertrag",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.inverter_gesamtenergieertrag",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 460,
        "y": 200,
        "wires": [
                "5fcffcb276a207e1"
        "id": "5fcffcb276a207e1",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/pv/8/get/exported",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 200,
        "wires": []
        "id": "ebd08ea3.75c5f",
        "type": "function",
        "name": "Berechnung",
        "func": "msg.payload = msg.payload * -1;\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 140,
        "wires": [
                "b54d4ffd1e13f824"
        "id": "13caf63d52a250b8",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/soc",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 920,
        "y": 500,
        "wires": []
        "id": "e5ee2bb810b6e5b9",
        "name": "Hausakku SOC",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_batterieladung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 420,
        "y": 500,
        "wires": [
                "13caf63d52a250b8"
        "id": "c224ee54b4dc3f3b",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/power",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 320,
        "wires": []
        "id": "e844d098effc0b56",
        "name": "Hausakku Lade-/Entladeleistung",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_lade_entladeleistung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 470,
        "y": 320,
        "wires": [
                "c224ee54b4dc3f3b"
        "id": "535076dc94ee8dda",
        "name": "Hausakku Gesamtladung",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_gesamtladung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 450,
        "y": 380,
        "wires": [
                "7266e2cf59ac1beb"
        "id": "7266e2cf59ac1beb",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/imported",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 380,
        "wires": []
        "id": "44a4f5ef0c5b567c",
        "name": "Hausakku Gesamtentladung",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_gesamtentladung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 460,
        "y": 440,
        "wires": [
                "f81c8706e2e7530a"
        "id": "f81c8706e2e7530a",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/exported",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 440,
        "wires": []
        "id": "eca40c603102ca88",
        "type": "mqtt-broker",
        "name": "OpenWB2",
        "broker": "192.168.178.3",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "ad5ff102.51ed",
        "type": "server",
        "name": "Home Assistant",
        "addon": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "",
        "connectionDelay": false,
        "cacheJson": false,
        "heartbeat": false,
        "heartbeatInterval": "",
        "statusSeparator": "",
        "enableGlobalContextStore": false
Ein Problem habe ich jetzt noch. Warum auch immer berechnet mir nun die OpenWB den Hausverbrauch nicht. Ich glaube das gehört eigentlich in ein anderes Thema. Wo kann der Fehler liegen?
(694.86 KiB) Noch nie heruntergeladen
(1.79 MiB) Noch nie heruntergeladen
(1.84 MiB) Noch nie heruntergeladen
tiffman
Beitrag von tiffman »
Vielen Dank für diesen tollen Thread und insbesondere an @alex für die Lösung und die Erklärungen per Video etc.
Eine Frage zur Wahl des RPi:
Spricht etwas dagegen, statt des Zero W den Zero 2 W zu nehmen? Er kostet nicht mehr, verbraucht idle nicht mehr Strom, hat aber einen leistungsstärkeren Prozessor und damit noch Reserve für eventuelle andere Anwendungen.
ran
Beitrag von ran »
Die Anbindung meiner beiden Huawei-Wechselrichter mit zwei "Huawei - OpenWB MQTT Bridges" funktioniert soweit.
Allerdings tritt das seltsame Phänomen auf, dass die MQTT-Verbindung zum 2. Wechselrichter, welcher "nur" ein Wechselrichter ist immer abbricht und erst bei einem Neustart wieder aktuelle Daten an die OpenWB liefert.
Hat jemand ähnliches beobachtet?
Ich habe mittlerweile sämtliche Kombinationen durch:
- Haken bei "Das hier ist ein weiterer Wechselrichter ohne Speicher und EVU" - noch schnellerer Verbindungsabbruch
- Normale Verbindung - tägl. min. 2 bis 3 Neustarts notwendig
- Separate MQTT-Anbindung an die OpenWB unter den "Geräte und Komponenten"-Einstellungen - keine Verbesserung
Der erste Raspberry Pi Zero der mit dem Master-WR verbunden ist läuft stabil und liefert ständig sämtliche Daten: WR, Luna, EVU
Alternativ könnte man auch den 2. WR mit den Huawei-Einstellungen der OpenWB einbinden, allerdings gibt es dann wieder die bekannten Abfrageprobleme.
