Alternative Anbindung von Huawei WR
danielrudolf
Re: Alternative Anbindung von Huawei WR
Beitrag von danielrudolf »
Hab es nun doch noch geschafft. Hab gestern in der Nacht mich noch mit Node-Red auseinandergesetzt. Dort habe ich es geschafft den Wert per Mqtt an die OpenWB zu senden.
sehr schön - Glückwunsch!
Kannst Du den Flow noch beistellen, dass alle etwas davon haben?
danielrudolf
Sehr gerne :)
Ich lasse ihm alle 2 Sekunden die Werte senden. Ein Wert von der Huawei habe ich *-1 gerechnet.
        "id": "b54d4ffd1e13f824",
        "type": "mqtt out",
        "z": "05ef9b6ff2d2232d",
        "name": "",
        "topic": "openWB/set/pv/8/get/power",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "eca40c603102ca88",
        "x": 920,
        "y": 140,
        "wires": []
        "id": "bce8f1d54263df19",
        "type": "api-current-state",
        "name": "Inverter Eingangsleistung",
        "server": "ad5ff102.51ed",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "sensor.inverter_eingangsleistung",
        "state_type": "str",
        "blockInputOverrides": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 450,
        "y": 140,
        "wires": [
                "ebd08ea3.75c5f"
        "id": "bf88582d62e42d3a",
        "type": "inject",
        "name": "",
        "props": [],
        "repeat": "2",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 110,
        "y": 220,
        "wires": [
                "60c9a819108d7648",
                "bce8f1d54263df19",
                "e5ee2bb810b6e5b9",
                "e844d098effc0b56",
                "535076dc94ee8dda",
                "44a4f5ef0c5b567c"
        "id": "60c9a819108d7648",
        "name": "Inverter Gesamtenergieertrag",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.inverter_gesamtenergieertrag",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 460,
        "y": 200,
        "wires": [
                "5fcffcb276a207e1"
        "id": "5fcffcb276a207e1",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/pv/8/get/exported",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 200,
        "wires": []
        "id": "ebd08ea3.75c5f",
        "type": "function",
        "name": "Berechnung",
        "func": "msg.payload = msg.payload * -1;\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 140,
        "wires": [
                "b54d4ffd1e13f824"
        "id": "13caf63d52a250b8",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/soc",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 920,
        "y": 500,
        "wires": []
        "id": "e5ee2bb810b6e5b9",
        "name": "Hausakku SOC",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_batterieladung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 420,
        "y": 500,
        "wires": [
                "13caf63d52a250b8"
        "id": "c224ee54b4dc3f3b",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/power",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 320,
        "wires": []
        "id": "e844d098effc0b56",
        "name": "Hausakku Lade-/Entladeleistung",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_lade_entladeleistung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 470,
        "y": 320,
        "wires": [
                "c224ee54b4dc3f3b"
        "id": "535076dc94ee8dda",
        "name": "Hausakku Gesamtladung",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_gesamtladung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 450,
        "y": 380,
        "wires": [
                "7266e2cf59ac1beb"
        "id": "7266e2cf59ac1beb",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/imported",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 380,
        "wires": []
        "id": "44a4f5ef0c5b567c",
        "name": "Hausakku Gesamtentladung",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "sensor.battery_gesamtentladung",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 460,
        "y": 440,
        "wires": [
                "f81c8706e2e7530a"
        "id": "f81c8706e2e7530a",
        "type": "mqtt out",
        "name": "",
        "topic": "openWB/set/bat/9/get/exported",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 930,
        "y": 440,
        "wires": []
        "id": "eca40c603102ca88",
        "type": "mqtt-broker",
        "name": "OpenWB2",
        "broker": "192.168.178.3",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "ad5ff102.51ed",
        "type": "server",
        "name": "Home Assistant",
        "addon": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "",
        "connectionDelay": false,
        "cacheJson": false,
        "heartbeat": false,
        "heartbeatInterval": "",
        "statusSeparator": "",
        "enableGlobalContextStore": false
Ein Problem habe ich jetzt noch. Warum auch immer berechnet mir nun die OpenWB den Hausverbrauch nicht. Ich glaube das gehört eigentlich in ein anderes Thema. Wo kann der Fehler liegen?
(694.86 KiB) Noch nie heruntergeladen
(1.79 MiB) Noch nie heruntergeladen
(1.84 MiB) Noch nie heruntergeladen
tiffman
Beitrag von tiffman »
Vielen Dank für diesen tollen Thread und insbesondere an @alex für die Lösung und die Erklärungen per Video etc.
Eine Frage zur Wahl des RPi:
Spricht etwas dagegen, statt des Zero W den Zero 2 W zu nehmen? Er kostet nicht mehr, verbraucht idle nicht mehr Strom, hat aber einen leistungsstärkeren Prozessor und damit noch Reserve für eventuelle andere Anwendungen.
openWB Pro (11 kW) mit standalone und Dimm- & Control-Kit
PV: 22 kWp, HUAWEI SUN2000-17KTL-M2
Tesla Model Y LR
Geplante WP: Lambda EU13L
ran
Beitrag von ran »
Die Anbindung meiner beiden Huawei-Wechselrichter mit zwei "Huawei - OpenWB MQTT Bridges" funktioniert soweit.
Allerdings tritt das seltsame Phänomen auf, dass die MQTT-Verbindung zum 2. Wechselrichter, welcher "nur" ein Wechselrichter ist immer abbricht und erst bei einem Neustart wieder aktuelle Daten an die OpenWB liefert.
Hat jemand ähnliches beobachtet?
Ich habe mittlerweile sämtliche Kombinationen durch:
- Haken bei "Das hier ist ein weiterer Wechselrichter ohne Speicher und EVU" - noch schnellerer Verbindungsabbruch
- Normale Verbindung - tägl. min. 2 bis 3 Neustarts notwendig
- Separate MQTT-Anbindung an die OpenWB unter den "Geräte und Komponenten"-Einstellungen - keine Verbesserung
Der erste Raspberry Pi Zero der mit dem Master-WR verbunden ist läuft stabil und liefert ständig sämtliche Daten: WR, Luna, EVU
Alternativ könnte man auch den 2. WR mit den Huawei-Einstellungen der OpenWB einbinden, allerdings gibt es dann wieder die bekannten Abfrageprobleme.
tiffman
Ich habe jetzt bei mir die Alex-Metzger-Lösung umgesetzt, doch sie funktioniert noch nicht ganz. Meine Situation: Ein Detail zur Verbindung der Alex-Metzger-Lösung mit dem WLAN des WR: Ich habe hier das WLAN-Kennwort eingegeben - nicht das WiFi-Konfigurationskennwort der FusionSolar (die beiden Kennwörter sind unterschiedlich).
Woran kann es noch liegen?
Tesla Model Y LR
Bridge bei Alex Lösung? Braucht es das wirklich?
Der Zero setzt WLAN-Huawei auf dein LAN um. In openWB werden alle Energiesystem-Module (Zähler, PV, Speicher) als MQTT-Gerät/Komponenten angelegt und die dort vergebenen ID's (findest du in der zugehörigen Komponente) müssen in Alex' Software eingetragen werden. Ich hoffe, ich liege da richtig, da ich Alex' Lösung selbst noch nicht praktiziert habe.
tiffman
aiole hat geschrieben: So Mai 12, 2024 4:55 pm Bridge bei Alex Lösung? Braucht es das wirklich?
Die Frage verstehe ich nicht ganz. Von Bridge habe ich doch gar nichts geschrieben. Die Lösung von Alex Metzger heißt allerdings Bridge (daher der Dateiname im Screenshot).
aiole hat geschrieben: So Mai 12, 2024 4:55 pm Der Zero setzt WLAN-Huawei auf dein LAN um. In openWB werden alle Energiesystem-Module (Zähler, PV, Speicher) als MQTT-Gerät/Komponenten angelegt und die dort vergebenen ID's (findest du in der zugehörigen Komponente) müssen in Alex' Software eingetragen werden. Ich hoffe, ich liege da richtig, da ich Alex' Lösung selbst noch nicht praktiziert habe.
Genau so habe ich es gemacht. Streng nach Anleitung. Siehe Screenshots.
Tesla Model Y LR
Pendragon
Beitrag von Pendragon »
Wenn du dich mit dem dongle verbinden willst dann darfst du nicht das Netz des Wechselrichters verwenden sondern muss dich mit deinem normalen WLAN verbinden
Opel Corsa-e mit 46kWh
Ich dachte, der Zero verbindet sich direkt auf's Huawei-Wifi und lässt den Dongle außen vor. Das ist ja das Ziel, dieses instabile Dongleteil zu eliminieren.
s. min 4:48
https://youtu.be/nb7wcyGZLEE?feature=shared
Die Bridgebezeichnung bei Alex ist ok, wenn das keine MQTT-bridge eines MQTT-brokers ist. Letzlich ist es ein Wifi 2 LAN-Adapter.
