OpenDTU (Hoymiles) Werte via JSON
DirkS
Beitrag von DirkS »
kennt sich jemand mit dem JSON Abfrage Modul aus?
Nachdem OpenDTU alle relevanten Daten aller verbundenen Hoymiles Inverter via MQTT nur über Middleware an die OpenWB senden kann und der Entwickler meint es wäre sehr viel Arbeit eine OpenWB Option einzubauen, wäre JSON eine andere Möglichkeit ohne Middleware an die Daten zu kommen.
Siehe hier: https://github.com/tbnobody/OpenDTU/issues/240
Das hier spuckt meine OpenDTU über [IP]/api/livedata/status aus:
[{"serial":"112181311701","name":"Holzpalast Süd","data_age":11559,"reachable":false,"producing":false,"limit_relative":100,"limit_absolute":350,"0":{"Power":{"v":0,"u":"W"},"Voltage":{"v":235.1999969,"u":"V"},"Current":{"v":0,"u":"A"},"Power DC":{"v":1.200000048,"u":"W"},"YieldDay":{"v":482,"u":"Wh"},"YieldTotal":{"v":111.3209991,"u":"kWh"},"Frequency":{"v":49.99000168,"u":"Hz"},"Temperature":{"v":21.60000038,"u":"°C"},"PowerFactor":{"v":0,"u":"%"},"ReactivePower":{"v":0,"u":"var"},"Efficiency":{"v":0,"u":"%"}},"1":{"Power":{"v":1.200000048,"u":"W"},"Voltage":{"v":24.10000038,"u":"V"},"Current":{"v":0.050000001,"u":"A"},"YieldDay":{"v":482,"u":"Wh"},"YieldTotal":{"v":111.3209991,"u":"kWh"},"Irradiation":{"v":0.292682916,"u":"%"}},"events":3},{"serial":"112180719948","name":"Holzpalast Ost Links","data_age":11678,"reachable":false,"producing":false,"limit_relative":100,"limit_absolute":300,"0":{"Power":{"v":0,"u":"W"},"Voltage":{"v":235.6000061,"u":"V"},"Current":{"v":0,"u":"A"},"Power DC":{"v":1,"u":"W"},"YieldDay":{"v":351,"u":"Wh"},"YieldTotal":{"v":0.843999982,"u":"kWh"},"Frequency":{"v":49.97000122,"u":"Hz"},"Temperature":{"v":21.70000076,"u":"°C"},"PowerFactor":{"v":0,"u":"%"},"ReactivePower":{"v":0,"u":"var"},"Efficiency":{"v":0,"u":"%"}},"1":{"Power":{"v":1,"u":"W"},"Voltage":{"v":19.70000076,"u":"V"},"Current":{"v":0.050000001,"u":"A"},"YieldDay":{"v":351,"u":"Wh"},"YieldTotal":{"v":0.843999982,"u":"kWh"},"Irradiation":{"v":0.289855093,"u":"%"}},"events":3},{"serial":"114181304338","name":"Mülltonnen","data_age":11377,"reachable":false,"producing":false,"limit_relative":100,"limit_absolute":600,"0":{"Power":{"v":0,"u":"W"},"Voltage":{"v":234.5,"u":"V"},"Current":{"v":0,"u":"A"},"Power DC":{"v":0.700000048,"u":"W"},"YieldDay":{"v":828,"u":"Wh"},"YieldTotal":{"v":5.251999855,"u":"kWh"},"Frequency":{"v":49.99000168,"u":"Hz"},"Temperature":{"v":22.39999962,"u":"°C"},"PowerFactor":{"v":0,"u":"%"},"ReactivePower":{"v":0,"u":"var"},"Efficiency":{"v":0,"u":"%"}},"1":{"Power":{"v":0.300000012,"u":"W"},"Voltage":{"v":18.60000038,"u":"V"},"Current":{"v":0.02,"u":"A"},"YieldDay":{"v":398,"u":"Wh"},"YieldTotal":{"v":2.50999999,"u":"kWh"},"Irradiation":{"v":0.086956523,"u":"%"}},"2":{"Power":{"v":0.400000006,"u":"W"},"Voltage":{"v":18.60000038,"u":"V"},"Current":{"v":0.02,"u":"A"},"YieldDay":{"v":430,"u":"Wh"},"YieldTotal":{"v":2.742000103,"u":"kWh"},"Irradiation":{"v":0.115942039,"u":"%"}},"events":3}]
Nun müsste man die Abfrage so gestalten um alle einzel Inverter Daten zu summieren. Zudem kommt YieldTotal in kWh, OpenWB will aber Wh.
Der Entwickler von OpenDTU meint hiermit
[.[]."0".Power.v] | add
könnten die einzel Inverterdaten summiert werden.
Grüße
Re: OpenDTU (Hoymiles) Werte via JSON
Det? Wo bist Du? Es geht um jq ;) .
https://github.com/tbnobody/OpenDTU/iss ... 1282277626
Ich wurde hier beglückt:
viewtopic.php?p=25063#p25063
Keine Hoymiles, sondern AE-Conversion-Modul-WR
@DirkS
Kannst Du bitte eine Ausgabe von
posten?
DirkS
Beitrag von DirkS »
aiole hat geschrieben: Di Okt 18, 2022 8:04 pm
@DirkS
posten?
Habe ich doch im ersten Post bereits
Sry, wer lesen kann... :roll:
Der Entwickler hat Recht.
Der gezeigte Ausdruck summiert die aktuellen Leistungen.
Für den Ertrag muss das folgende Filter verwendet werden.
[.[]."0".YieldTotal.v]|add *1000
Dann sollte das summiert und in Wh passen.
DirkS
Beitrag von DirkS »
Hi Det,
das ist schonmal cool. Mehr muss man nicht eintragen? Oder ist da noch mehr code notwendig? Kannst du das für Dummies erklären?
URL und die beiden Filter Ausdrücke eingeben, dann sollte schon was kommen.
Das ist die Erklärung ;)
Muss nicht immer schwierig sein.
thomas67648
Beitrag von thomas67648 »
Ich scheitere am selben Problem
Meine OpenDTU hat zwar nur einen Wechselrichter verknüpft, aber das macht evtl für die Syntax keinen Unterschied
und ich bekomme die Syntax ohne die add-Funktion nicht hin
URL ist eingetragen
URL/api/livedata/status
dann die Filter
Und bekomme von der OpenWB im Status den Fehler
Störungsbeschreibung <class 'ValueError'> Cannot index array with string "0"
Meine Versuche mit ."0".Power.v führen auch in Fehlermeldungen
Gruß Thomas
thomas67648
So klappt es:
dann die Filter
.total.Power.v
.total.YieldTotal.v *1000
Gruß Thomas
Dann liefert dein Wechselrichter ein anderes JSON zurück ;)
