Seite 9 von 22
Re: Support: Manuell + Berechnung
Verfasst: So Dez 05, 2021 1:58 pm
von yankee
Normalerweise verwende ich EVNotify, weil ich das gerade kaputt gemacht habe, habe ich temporär auf Manuell+Berechnung umgestellt. Der SoC ändert sich nicht. Im Log bekomme ich:
modules/soc_manual/main.sh: Zeile 101: /var/www/html/openWB/ramdisk/manual_soc_meter_lp1: Keine Berechtigung
Verfasst: Do Jan 13, 2022 12:52 pm
von philipp123
2022-01-13 13:04:14: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:04:13: PID: 11697: SoC Manual: 55% + 0.04536 kWh = 55.1418%
2022-01-13 13:04:13: PID: 11697: SoC Manual: SoC-Gain: Charged (0.054 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.1%
2022-01-13 13:04:13: PID: 11697: SoC Manual: Charged: 272.943 kWh -> 272.997 kWh = 0.054 kWh
2022-01-13 13:03:55: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:03:53: PID: 10181: SoC Manual: 55% + 0.03864 kWh = 55.1207%
2022-01-13 13:03:53: PID: 10181: SoC Manual: SoC-Gain: Charged (0.046 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.1%
2022-01-13 13:03:53: PID: 10181: SoC Manual: Charged: 272.943 kWh -> 272.989 kWh = 0.046 kWh
2022-01-13 13:03:34: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:03:33: PID: 8709: SoC Manual: 55% + 0.03276 kWh = 55.1024%
2022-01-13 13:03:33: PID: 8709: SoC Manual: SoC-Gain: Charged (0.039 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.1%
2022-01-13 13:03:33: PID: 8709: SoC Manual: Charged: 272.943 kWh -> 272.982 kWh = 0.039 kWh
2022-01-13 13:03:14: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:03:13: PID: 7245: SoC Manual: 55% + 0.02604 kWh = 55.0814%
2022-01-13 13:03:13: PID: 7245: SoC Manual: SoC-Gain: Charged (0.031 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.1%
2022-01-13 13:03:13: PID: 7245: SoC Manual: Charged: 272.943 kWh -> 272.974 kWh = 0.031 kWh
2022-01-13 13:02:54: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:02:53: PID: 5720: SoC Manual: 55% + 0.01932 kWh = 55.0604%
2022-01-13 13:02:53: PID: 5720: SoC Manual: SoC-Gain: Charged (0.023 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.1%
2022-01-13 13:02:53: PID: 5720: SoC Manual: Charged: 272.943 kWh -> 272.966 kWh = 0.023 kWh
2022-01-13 13:02:34: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:02:33: PID: 4191: SoC Manual: 55% + 0.0126 kWh = 55.0394%
2022-01-13 13:02:33: PID: 4191: SoC Manual: SoC-Gain: Charged (0.015 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-01-13 13:02:33: PID: 4191: SoC Manual: Charged: 272.943 kWh -> 272.958 kWh = 0.015 kWh
2022-01-13 13:02:17: Lp1: SoC: 65 (LV0) at 76 getAndWriteSoc modules/soc_vag/main.sh
2022-01-13 13:02:14: Lp1: Requesting SoC (LV0) at 70 getAndWriteSoc modules/soc_vag/main.sh
2022-01-13 13:02:13: PID: 2719: SoC Manual: 55% + 0.00672 kWh = 55.021%
2022-01-13 13:02:13: PID: 2719: SoC Manual: SoC-Gain: Charged (0.008 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-01-13 13:02:13: PID: 2719: SoC Manual: Charged: 272.943 kWh -> 272.951 kWh = 0.008 kWh
2022-01-13 13:01:54: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:01:53: PID: 1187: SoC Manual: 55% + 4.30836 kWh = 68.4636%
2022-01-13 13:01:53: PID: 1187: SoC Manual: SoC-Gain: Charged (5.129 kWh) * efficiency (84%) / battery-size (32 kWh) = 13.5%
2022-01-13 13:01:53: PID: 1187: SoC Manual: Charged: 267.814 kWh -> 272.943 kWh = 5.129 kWh
2022-01-13 13:01:34: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:01:33: PID: 32149: SoC Manual: 55% + 4.30164 kWh = 68.4426%
2022-01-13 13:01:33: PID: 32149: SoC Manual: SoC-Gain: Charged (5.121 kWh) * efficiency (84%) / battery-size (32 kWh) = 13.4%
2022-01-13 13:01:33: PID: 32149: SoC Manual: Charged: 267.814 kWh -> 272.935 kWh = 5.121 kWh
2022-01-13 13:01:14: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:01:13: PID: 30683: SoC Manual: 55% + 4.29576 kWh = 68.4242%
2022-01-13 13:01:13: PID: 30683: SoC Manual: SoC-Gain: Charged (5.114 kWh) * efficiency (84%) / battery-size (32 kWh) = 13.4%
2022-01-13 13:01:13: PID: 30683: SoC Manual: Charged: 267.814 kWh -> 272.928 kWh = 5.114 kWh
2022-01-13 13:00:54: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:00:53: PID: 29164: SoC Manual: 55% + 4.28904 kWh = 68.4032%
2022-01-13 13:00:53: PID: 29164: SoC Manual: SoC-Gain: Charged (5.106 kWh) * efficiency (84%) / battery-size (32 kWh) = 13.4%
2022-01-13 13:00:53: PID: 29164: SoC Manual: Charged: 267.814 kWh -> 272.92 kWh = 5.106 kWh
2022-01-13 13:00:35: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-13 13:00:33: PID: 27700: SoC Manual: 55% + 4.28232 kWh = 68.3822%
2022-01-13 13:00:33: PID: 27700: SoC Manual: SoC-Gain: Charged (5.098 kWh) * efficiency (84%) / battery-size (32 kWh) = 13.4%
2022-01-13 13:00:33: PID: 27700: SoC Manual: Charged: 267.814 kWh -> 272.912 kWh = 5.098 kWh
Bei mir ist gerade mal wieder der manuelle SOC zurück auf den ursprünglich eingetragenen Wert gesprungen um 2022-01-13 13:02:13. Es hat einfach weiter geladen, es wurde nichts unterbrochen oder ähnliches.
Sehe gerade, dass ich noch die Version vom 10.12. einsetze und die Änderungen vom 28.12. noch nicht. Muss ich wohl mal ein Update machen. Ich lasse aber mal den Rest drin, damit es dokumentiert ist.
Verfasst: Fr Jan 14, 2022 3:59 pm
von HSC
yankee hat geschrieben: So Dez 05, 2021 1:58 pm Normalerweise verwende ich EVNotify, weil ich das gerade kaputt gemacht habe, habe ich temporär auf Manuell+Berechnung umgestellt. Der SoC ändert sich nicht. Im Log bekomme ich:
Ist das irgendwann gefixt worden?
Habe heute nach längerer Zeit mal wieder auf die Berechnung umgestellt und vorsichtshalber noch die 1.9.250 (2021-12-05 11:36:56) drauf.
Irgendwie wird da leider nichts berechnet:
2022-01-14 16:37:25: Lp1: manualMeter: 920.000 (LV1) at 103 main modules/soc_manual/main.sh
2022-01-14 16:37:25: Lp1: manual SoC: 65 (LV1) at 92 main modules/soc_manual/main.sh
2022-01-14 16:37:25: Lp1: currentMeter: 920.000 (LV1) at 82 main modules/soc_manual/main.sh
2022-01-14 16:37:25: Lp1: Calculating manual SoC (LV1) at 75 main modules/soc_manual/main.sh
2022-01-14 16:37:25: Lp1: timer = 1 (LV1) at 69 main modules/soc_manual/main.sh
2022-01-14 16:37:24: Lp2: Nothing to do yet. Incrementing timer. (LV0) at 93 main /var/www/html/openWB/modules/soc_vag/main.sh
2022-01-14 16:37:16: Lp1: --- Manual SoC end --- (LV1) at 136 main modules/soc_manual/main.sh
2022-01-14 16:37:16: Lp1: Nothing to do yet. Incrementing timer. (LV1) at 72 main modules/soc_manual/main.sh
2022-01-14 16:37:16: Lp1: timer = 0 (LV1) at 69 main modules/soc_manual/main.sh
2022-01-14 16:37:15: Lp2: Nothing to do yet. Incrementing timer. (LV0) at 93 main /var/www/html/openWB/modules/soc_vag/main.sh
2022-01-14 16:37:05: Lp1: --- Manual SoC end --- (LV1) at 136 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: newSoc: 65 (LV1) at 128 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: currentSocDiff: 0 (LV1) at 120 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: currentEffectiveMeterDiff: 0 (100 %) (LV1) at 118 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: currentMeterDiff: 0 (LV1) at 116 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: currentSoc: 65 (LV1) at 112 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: manualMeter: 920.000 (LV1) at 103 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: manual SoC: 65 (LV1) at 92 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: currentMeter: 920.000 (LV1) at 82 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: Calculating manual SoC (LV1) at 75 main modules/soc_manual/main.sh
2022-01-14 16:37:05: Lp1: timer = 1 (LV1) at 69 main modules/soc_manual/main.sh
2022-01-14 16:37:04: Lp2: Nothing to do yet. Incrementing timer. (LV0) at 93 main /var/www/html/openWB/modules/soc_vag/main.sh
2022-01-14 16:36:56: Lp1: --- Manual SoC end --- (LV1) at 136 main modules/soc_manual/main.sh
2022-01-14 16:36:56: Lp1: Nothing to do yet. Incrementing timer. (LV1) at 72 main modules/soc_manual/main.sh
2022-01-14 16:36:56: Lp1: timer = 0 (LV1) at 69 main modules/soc_manual/main.sh
2022-01-14 16:36:55: Lp2: Nothing to do yet. Incrementing timer. (LV0) at 93 main /var/www/html/openWB/modules/soc_vag/main.sh
2022-01-14 16:36:45: Lp1: --- Manual SoC end --- (LV1) at 136 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: newSoc: 65 (LV1) at 128 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: currentSocDiff: 0 (LV1) at 120 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: currentEffectiveMeterDiff: 0 (100 %) (LV1) at 118 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: currentMeterDiff: 0 (LV1) at 116 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: currentSoc: 65 (LV1) at 112 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: manualMeter: 919.000 (LV1) at 103 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: manual SoC: 65 (LV1) at 92 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: currentMeter: 919.000 (LV1) at 82 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: Calculating manual SoC (LV1) at 75 main modules/soc_manual/main.sh
2022-01-14 16:36:45: Lp1: timer = 1 (LV1) at 69 main modules/soc_manual/main.sh
Kann ich irgendwo in den Innereien was näheres dazu sehen?
Verfasst: Fr Jan 14, 2022 4:36 pm
von philipp123
Gab am 10.12. Uund 28.12. nen komplettem Umbau. Damit rechnet es bei mir.
Verfasst: Fr Jan 14, 2022 4:37 pm
von HSC
Ok, danke Dir.
Verfasst: So Jan 16, 2022 11:01 am
von HSC
philipp123 hat geschrieben: Fr Jan 14, 2022 4:36 pm Gab am 10.12. Uund 28.12. nen komplettem Umbau. Damit rechnet es bei mir.
Nach update am Freitag läuft es nun wieder, nochmals danke für den Hinweis.
Verfasst: Mo Jan 24, 2022 12:13 pm
von philipp123
2022-01-24 12:37:23: PID: 25393: SoC Manual: 67% + 0.01932 kWh = 67.0604%
2022-01-24 12:37:23: PID: 25393: SoC Manual: SoC-Gain: Charged (0.023 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.1%
2022-01-24 12:37:23: PID: 25393: SoC Manual: Charged: 300.845 kWh -> 300.868 kWh = 0.023 kWh
2022-01-24 12:37:04: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
  RequestsDependencyWarning)
/usr/lib/python3/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.8) or chardet (3.0.4) doesn't match a supported version!
2022-01-24 12:37:03: PID: 23943: SoC Manual: 67% + 0.0126 kWh = 67.0394%
2022-01-24 12:37:03: PID: 23943: SoC Manual: SoC-Gain: Charged (0.015 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-01-24 12:37:03: PID: 23943: SoC Manual: Charged: 300.845 kWh -> 300.86 kWh = 0.015 kWh
2022-01-24 12:36:45: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-24 12:36:44: PID: 22435: SoC Manual: 67% + 0.00672 kWh = 67.021%
2022-01-24 12:36:44: PID: 22435: SoC Manual: SoC-Gain: Charged (0.008 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-01-24 12:36:44: PID: 22435: SoC Manual: Charged: 300.845 kWh -> 300.853 kWh = 0.008 kWh
2022-01-24 12:36:27: Lp1: SoC: 70 (LV0) at 76 getAndWriteSoc modules/soc_vag/main.sh
2022-01-24 12:36:25: Lp1: Requesting SoC (LV0) at 70 getAndWriteSoc modules/soc_vag/main.sh
2022-01-24 12:36:24: PID: 20911: SoC Manual: 67% + 1.33896 kWh = 71.1843%
2022-01-24 12:36:24: PID: 20911: SoC Manual: SoC-Gain: Charged (1.594 kWh) * efficiency (84%) / battery-size (32 kWh) = 4.2%
2022-01-24 12:36:24: PID: 20911: SoC Manual: Charged: 299.251 kWh -> 300.845 kWh = 1.594 kWh
2022-01-24 12:36:05: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
2022-01-24 12:36:04: PID: 19426: SoC Manual: 67% + 1.3356 kWh = 71.1738%
2022-01-24 12:36:04: PID: 19426: SoC Manual: SoC-Gain: Charged (1.59 kWh) * efficiency (84%) / battery-size (32 kWh) = 4.2%
2022-01-24 12:36:04: PID: 19426: SoC Manual: Charged: 299.251 kWh -> 300.841 kWh = 1.59 kWh
2022-01-24 12:35:45: Lp1: Nothing to do yet. Incrementing timer. (LV0) at 93 main modules/soc_vag/main.sh
Wieder mal ein Reset der geladenen Energiemenge beim manuellen SOC. Muss mich wohl doch mal mit dem neuen Code auseinandersetzen, war jetzt das 3. Mal.
Die RequestsDependencyWarning ist auch neu (bei meinem selbst installierten Pie).
Verfasst: Mo Jan 24, 2022 5:23 pm
von HSC
Habe hier auch ein neues feature in der 251 gefunden.
Hatte mich nachmittags über 0% im WB- Display gewundert. LP2 läuft über Berechnung.
Im neuen Ladevorgang habe ich dann direkt mal 90% gesetzt, inzwischen bin ich schon bei 109%....🤔
 2022-01-24 18:14:08: PID: 21773: SoC Manual: 90% + 2 kWh = 108.182%
2022-01-24 18:14:08: PID: 21773: SoC Manual: SoC-Gain: Charged (2 kWh) * efficiency (100%) / battery-size (11 kWh) = 18.2%
2022-01-24 18:14:08: PID: 21773: SoC Manual: Charged: 957 kWh -> 959 kWh = 2 kWh
2022-01-24 18:14:06: Lp1: Nothing to do yet. Incrementing timer. (LV1) at 74 main modules/soc_id/main.sh
2022-01-24 18:14:06: Lp1: timer = 1020 (LV1) at 69 main modules/soc_id/main.sh
2022-01-24 18:13:59: PID: 20209: SoC Manual: 90% + 2 kWh = 108.182%
2022-01-24 18:13:59: PID: 20209: SoC Manual: SoC-Gain: Charged (2 kWh) * efficiency (100%) / battery-size (11 kWh) = 18.2%
2022-01-24 18:13:59: PID: 20209: SoC Manual: Charged: 957 kWh -> 959 kWh = 2 kWh
2022-01-24 18:13:57: Lp1: Nothing to do yet. Incrementing timer. (LV1) at 74 main modules/soc_id/main.sh
2022-01-24 18:13:57: Lp1: timer = 1019 (LV1) at 69 main modules/soc_id/main.sh
2022-01-24 18:13:48: PID: 18680: SoC Manual: 90% + 1 kWh = 99.0909%
😳 knapp 140 % nun ...
Verfasst: So Jan 30, 2022 1:04 pm
von bergfex
Was mir schon seit einigen Versionen auffällt: Wenn I für Import steht und E für Export, also Bezug und Einspeisung, dann habe ich das Gefühl, dass bei den in Klammern angezeigten Werten I und E vertauscht sind. Das gilt für Netz-Exp. oder Netz-Imp. und für Speicher Ladung bzw. Entladung. Oder täusche ich mich da?
Einfacher wär das halt und weniger verwirrend wenn die Deutschen Begriffe (Einspeisung und Bezug) verwendet würden, aber mit dieser Bitte bin ich leider nicht durchgekommen.
Verfasst: Di Feb 01, 2022 12:34 pm
von philipp123
Also beim Umbau des manuellen SOC-Moduls ist definitiv etwas schief gelaufen.
Wieder wurde die geladene Strommenge einfach genullt.
Und noch heftiger, das hatte ich noch garnicht: Der manuell eingetragene SOC wurde erst genommen und darauf gerechnet und plötzlich ohne Nutzerinteraktion wieder auf den alten Wert zurückgesetzt. Ich habe Kommentarzeilen im Log zur Verdeutlichung gemacht.
2022-02-01 11:57:05: PID: 12161: SoC Manual: 45% + 0.0126 kWh = 45.0394%
2022-02-01 11:57:05: PID: 12161: SoC Manual: SoC-Gain: Charged (0.015 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-02-01 11:57:05: PID: 12161: SoC Manual: Charged: 325.623 kWh -> 325.638 kWh = 0.015 kWh
2022-02-01 11:56:44: PID: 10583: SoC Manual: 45% + 0.00588 kWh = 45.0184%
2022-02-01 11:56:44: PID: 10583: SoC Manual: SoC-Gain: Charged (0.007 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-02-01 11:56:44: PID: 10583: SoC Manual: Charged: 325.623 kWh -> 325.63 kWh = 0.007 kWh
====> Grundloser Sprung zurück auf 45%, obwohl letzter manueller Wert 51% war
2022-02-01 11:56:24: PID: 9032: SoC Manual: 51% + 0.01932 kWh = 51.0604%
2022-02-01 11:56:24: PID: 9032: SoC Manual: SoC-Gain: Charged (0.023 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.1%
2022-02-01 11:56:24: PID: 9032: SoC Manual: Charged: 325.6 kWh -> 325.623 kWh = 0.023 kWh
2022-02-01 11:56:04: PID: 7504: SoC Manual: 51% + 0.0126 kWh = 51.0394%
2022-02-01 11:56:04: PID: 7504: SoC Manual: SoC-Gain: Charged (0.015 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-02-01 11:56:04: PID: 7504: SoC Manual: Charged: 325.6 kWh -> 325.615 kWh = 0.015 kWh
2022-02-01 11:55:47: PID: 5886: SoC Manual: 51% + 0.00672 kWh = 51.021%
2022-02-01 11:55:47: PID: 5886: SoC Manual: SoC-Gain: Charged (0.008 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-02-01 11:55:47: PID: 5886: SoC Manual: Charged: 325.6 kWh -> 325.608 kWh = 0.008 kWh
===> Manuelle Eingabe 51% als Startpunkt, da ja Reset geladen auf 0
2022-02-01 11:55:25: PID: 4211: SoC Manual: 45% + 0.18144 kWh = 45.567%
2022-02-01 11:55:25: PID: 4211: SoC Manual: SoC-Gain: Charged (0.216 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.6%
2022-02-01 11:55:25: PID: 4211: SoC Manual: Charged: 325.384 kWh -> 325.6 kWh = 0.216 kWh
2022-02-01 11:55:05: PID: 2593: SoC Manual: 45% + 0.17472 kWh = 45.546%
2022-02-01 11:55:05: PID: 2593: SoC Manual: SoC-Gain: Charged (0.208 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.5%
2022-02-01 11:55:05: PID: 2593: SoC Manual: Charged: 325.384 kWh -> 325.592 kWh = 0.208 kWh
2022-02-01 11:46:45: PID: 25847: SoC Manual: 45% + 0.01344 kWh = 45.042%
2022-02-01 11:46:45: PID: 25847: SoC Manual: SoC-Gain: Charged (0.016 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-02-01 11:46:45: PID: 25847: SoC Manual: Charged: 325.384 kWh -> 325.4 kWh = 0.016 kWh
2022-02-01 11:46:25: PID: 24312: SoC Manual: 45% + 0.00672 kWh = 45.021%
2022-02-01 11:46:25: PID: 24312: SoC Manual: SoC-Gain: Charged (0.008 kWh) * efficiency (84%) / battery-size (32 kWh) = 0.0%
2022-02-01 11:46:25: PID: 24312: SoC Manual: Charged: 325.384 kWh -> 325.392 kWh = 0.008 kWh
===> Plötzlich wird der geladen-Wert wieder auf 0 zurück gesetzt
2022-02-01 11:46:05: PID: 22725: SoC Manual: 45% + 2.05716 kWh = 51.4286%
2022-02-01 11:46:05: PID: 22725: SoC Manual: SoC-Gain: Charged (2.449 kWh) * efficiency (84%) / battery-size (32 kWh) = 6.4%
2022-02-01 11:46:05: PID: 22725: SoC Manual: Charged: 322.935 kWh -> 325.384 kWh = 2.449 kWh
2022-02-01 11:45:45: PID: 21143: SoC Manual: 45% + 2.05128 kWh = 51.4103%
2022-02-01 11:45:45: PID: 21143: SoC Manual: SoC-Gain: Charged (2.442 kWh) * efficiency (84%) / battery-size (32 kWh) = 6.4%
2022-02-01 11:45:45: PID: 21143: SoC Manual: Charged: 322.935 kWh -> 325.377 kWh = 2.442 kWh
===> Ladebeginn mit 45% maneuller Eingabe
Edit2: Hab die aktuelle Version vo manuellen SOC vom 28.12.2021 laufen. Gesamtstand war der 25.01.2022.
